MK7 Heater Temperature Actuator
Postby oldarry » Thu Nov 30, 2017 3:19 pm
Morning All
I'm stuck. And so is the heater on f f f f freezing cold. It looks like the temp knob isn't doing anything. I've read an old thread about the potentiometer, the cables and the actuator. I've had the pot out and metered it, it varies in stages rather than very gradually but I would guess that counts as working? But here's the thing, where is the actuator on the heater unit? and how much dash comes out to get there? I just can't find it. Anyone got a pic?
Cheers chaps
2.2 85.280 fwd aircon 2008
Sent from my Nexus 5 using Tapatalk
oldarry
Re: MK7 Heater Temperature Actuator
Postby v8dave » Thu Nov 30, 2017 9:23 pm
Could be the actuator failed. Aircon ones are different to non-aircon, I managed to get one from a spanish breakers via ebay.
Heater actuator is under a cover on the left side of the heater unit.
Remove the glove box.
Remove the central panel below the heater controls and gearlever.
The temperature actuator is item 4
You may need to remove a duct to get to all the screws.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby oldarry » Fri Dec 01, 2017 12:59 am
Dave you're brilliant I can't thank you enough. I somehow got it in my head that it looked like item 1, whatever that is. What is that? Anyhow I'll have a mess with it at the weekend and hopefully work out which bit is not working. I guess the actuator itself is tad thin on the ground if you had to fleabay Spain for one.
oldarry
Postby Dan T » Sat Dec 02, 2017 10:04 pm
You can manually menouver the motor to hot while you search for a replacement.
They’re £120 from Ford last time I fitted one.
Dan T
Postby v8dave » Sun Dec 03, 2017 3:56 pm
Item 1 is the actuator for the recirculation flap.
v8dave
Postby oldarry » Sun Dec 03, 2017 8:37 pm
Got it out, tested the loom- seem all ok. the wire colours differ from v8daves old post but was able to work out from the description.
Good thinking DanT I was hoping to just adjust the flap to hot for now but there's a spring return and gravity to contend with so I don't see it staying put without something to hold it- such as the dead motor!
There's not much in there really, an electronics tech could probably work out which components aren't working, I haven't a scooby.
After some thought I put power on the motor though which didn't budge so I took it apart. Problem right there on the brushes. Totally chowdered.
And they're silly money or need importing. Ho hum.
oldarry
Postby bigjohnthomas » Mon Dec 04, 2017 9:18 am
You can fix it for 15 quid
There's a thread somewhere I think it was big john thomas or something
There's one off a car that's the same except for the plastic bit in the middle
I'll have a look
bigjohnthomas
Postby bigjohnthomas » Mon Dec 04, 2017 9:20 am
Now then
Now then
How's about that then?
viewtopic.php?f=5&t=163776&hilit=Spoke
bigjohnthomas
Postby bigjohnthomas » Mon Dec 04, 2017 9:33 am
bigjohnthomas
Postby oldarry » Mon Dec 04, 2017 10:53 am
Ha ha I'm such a Muppet I just replied to your two years ago thread
Cheers BJ, and in the words of a Canadian Yoo toober 'thats the allcock for dolly'
oldarry
Postby bigjohnthomas » Mon Dec 04, 2017 12:21 pm
:lol:
have you fixed it yet :P
bigjohnthomas
Postby oldarry » Mon Dec 04, 2017 12:46 pm
No, the fleabay scrapyard teleport system's on the blink again so they're having to send it by post
oldarry
Postby oldarry » Sun Dec 10, 2017 8:05 pm
All done thank frug. Now able to melt snow off the screen
oldarry
Postby bigjohnthomas » Sun Dec 10, 2017 8:15 pm
About time too :lol:
bigjohnthomas
Postby jumbo 57 » Sun Dec 10, 2017 8:34 pm
oldarry wrote: and in the words of a Canadian Yoo toober that's the allcock for dolly
Good ol AVE.
https://www.youtube.com/watch?v=7z1oF_TTmZE :lol:
Keep your Dick in a vice!
jumbo 57
