Dont think any mk7s had solid pulleys mate I've a 57 and mate has a 56 and both have the rubber and metal crank pulleyCal1990 wrote:I’ve a hell of a squeeking on my 2012 transit. The crank pulley rubber bung is badly perished looking at it, my question is..... earlier mk7 transit had a solid crank pulley with no massive rubber bung... is this exact same dimensions width etc as later mk7 as I’m thinking this would work in the meantime till I get some cash together to get a ford one
Cal1990 wrote:I mean solid as in a metal one mate without the rubber....
bambi mk 1 wrote:I have fitted them with no problems,in fact some Luk clutch flywheel mk 7 kits come with a solid crank pulley in the box
karl wrote:bambi mk 1 wrote:I have fitted them with no problems,in fact some Luk clutch flywheel mk 7 kits come with a solid crank pulley in the box
same here
if one breaks up i just put a solid one on them, it make no difference to engine performance
i have bout 5 in stock (second-hand though) but every time a call out to a knocking crank pulley for a massive company in Manchester i always put a second hand solid crank pulley on them
Jim Archer wrote:What sort of squeak gives a failing pulley away? As I've got a intermittant/irregular one at idle.
Jim
