help needed When you park the van the lights and the warning
Re: help needed When you park the van the lights and the war
Postby mjsroofing » Fri Dec 08, 2017 10:02 pm
henk_t4 wrote:
mjsroofing wrote:Could this be a dodgy front battery
thanks, with the batterycharger connected all goes well. so I have to buy 2 new batterys ( they are connected together)
Verstuurd vanaf mijn SM-N910F met Tapatalk
Or just the front battery.
www.mjsroofing.co.uk
2009 2.2 tdci 115ps just over 51k and sweet as a nut ( so far )
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby henk_t4 » Thu Dec 14, 2017 2:37 pm
I replaced both because they are connected together for the hydraulics for the tailgate, but the warninglights still come on
henk_t4
Postby henk_t4 » Thu Dec 14, 2017 2:41 pm
henk_t4 wrote:
mjsroofing wrote:
henk_t4 wrote:[quote="mjsroofing"]Could this be a dodgy front battery
Verstuurd vanaf mijn SM-N910F met Tapatalk[/quote]
can I take out some wires of the bcm? because now its draining my new batterys
henk_t4
Postby Airthies » Sat Dec 16, 2017 3:08 pm
You said it was ok with the battery charger connected?
Are all systems, lights, functions, working properly when it's connected to a charger?
Or
When it is running?
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby henk_t4 » Sat Dec 16, 2017 3:39 pm
it was ok but later on it didnt work anymore, when running every thing works fine, when I park the warninglights come on and some times the lights as well, I take one of the big connectors of the bcm when I park the car
henk_t4
Postby henk_t4 » Tue Dec 19, 2017 4:05 pm
henk_t4 wrote:it was ok but later on it didnt work anymore, when running every thing works fine, when I park the warninglights come on and some times the lights as well, I take one of the big connectors of the bcm when I park the car
now even during the drive the wipers go on and the warning lights come on
henk_t4
Postby henk_t4 » Mon Dec 25, 2017 10:41 pm
but when driving the swiches will work.
so if I park the van what to do?
now I take the big connector out of the bcm. or shall I take the power off the bcm or cut some wires from the bcm connector (the warninglights) and put a switch between them ?
henk_t4
Postby coonak » Tue Dec 26, 2017 4:36 pm
Take it to a professional, don't butcher your loom up.
98 Hiace
2000 Hiace
2003 125 280 gone injectors!
2010 85 280 gone ULEZ!
....68 105 280 Custom eco blue
coonak
Postby henk_t4 » Tue Dec 26, 2017 4:39 pm
if I only knew where to find the professional, certainly not the ford dealer
henk_t4
Postby Airthies » Wed Dec 27, 2017 11:34 am
You need to get to the bottom of the issue. Cutting wires and adding switches is not going to sort why it has gone this way!
If you can't sort it now then either keep diconecting main plug on BCM or add batery isolator.
Could be poor earth causing failures?
Check and replace engine earth cable from starter to chassis and from battery to chassis and check CONNECTIONS ARE GOOD! And check rest of earth points on iner wings, door pillars under dash etc.
Then replace BCM you can pick them up for £15-25 nowadays. Then just needs programing to your van.
V86+patch
V86.04
X-Prog
C81
Airthies
