henk_t4 wrote:can I take a fuse away, is it a bad battery? bcm? it is a 2.4 mk7 2007 rwd
Verstuurd vanaf mijn SM-N910F met Tapatalk
Airthies wrote:What lights are on? The main head (driving) lights and Orange hazard/indicators?
What warnings are on? Any on dashboard?
Is it after starting the problems have come?
Or after stopping?
Is the key out and all switches off?
Airthies wrote:Is it ok when it's running?
Airthies wrote:Fuse 54 (30amp) is supply to high &low beam front lights.
But high and low are switched on by relays R11 (low beam) & R13 (high beam)
Which are controled by the BCM and F48 (5amp) fuse.
Hazard lights are controlled by the BCM
henk_t4 wrote:Airthies wrote:Fuse 54 (30amp) is supply to high &low beam front lights.
no fuse for hazard lights?
Airthies wrote:The hazard/indicator lights are fed direct from BCM circuit board.
No fuse between lights and BCM board.
My guess is something has fried your BCM.
I would aquire a new BCM (they are quite cheap now from a breakers, last one I bought was £15). And have that programmed to your vehicle.
Also replace the earth strap from your engine to front chassis leg and ensure good connections there, and at battery box conection.
henk_t4 wrote:Airthies wrote:The hazard/indicator lights are fed direct from BCM circuit board.
can I cut some wires on one of the bcm connectors? because it draines the battery's
mjsroofing wrote:Could this be a dodgy front battery
