Hi guys, really hoping someone can help.
My 2011 2.4 115hp rwd tranny has a few problems. It started with intermittent rough idling, well surging. Usually when it's warm but not all the time and sometimes when you release the clutch it surges slightly.
Since then it's developed starting problems, again when warm. It starts and cuts out immediately, can take anywhere between 2 to 7 attempts to fire up and run.
I've put it on a normal garage diagnostics but no faults.
I've heard about prv problems? Do you think it might be this and are these faults linked?
Anyhelp would be appreciated as you know what it's like. If the vans not running you can't work
Cheers guys!
