Mark 7 brake bleeding
Re: Mark 7 brake bleeding
Postby Brains_transit » Wed Dec 13, 2017 9:37 pm
knobby1 wrote:
Brains_transit wrote:I asked if it works on my my van since the eml327 isn't compatible with a 2002 and the guy said
"hi, yes it will work fine. Thanks" I have a feeling it won't work :lol:
The ELM-327 I linked to will indeed work on Mk6 & Mk7 machines.....there's also one which has a separate "CAN" switch which also works, I think our Ned alerted us to it.... this one:
https://www.ebay.com.au/itm/USB-Modifie ... 2749.l2649
Both of them work fine on Mk6 & Mk7..!
Just make sure you use the correct Windoze drivers and the latest Forscan, you''l be fine.
I'm using the wifi one and it links to the elm and when it reads it's say please insert the key and switch on but the keys in
Brains_transit
Postby knobby1 » Wed Dec 13, 2017 10:04 pm
Brains_transit wrote:I'm using the wifi one and it links to the elm and when it reads it's say please insert the key and switch on but the keys in
I don't have the WiFi ones, both ones I have are just the USB jobbies...both work fine on 6's & 7's... :mrgreen:
Pretty sure Ned has the one with the "can" switch and it works with Forscan on his Mk6... :?
Postby Brains_transit » Wed Dec 13, 2017 10:10 pm
What year mk6 did you use it on as I read only 2004 onwards and all tdci but mine is tddi
Brains_transit
Postby knobby1 » Wed Dec 13, 2017 10:13 pm
Brains_transit wrote:What year mk6 did you use it on as I read only 2004 onwards and all tdci but mine is tddi
The Mk6's I ran were both TDDi's, haven't played with a TDCi Mk6.... I believe one was a 2002 and the other a 2005..! So one analogue and the other digital... :?
