paul2012 wrote:browuk wrote:dumper wrote:Just done a search on forum for twin alloy wheels come up with this http://www.arconic.com/alcoawheels/cata ... hicles.pdf
Found that too with a search but got error when I tried to post the link . 1699 bucks for the 4 plus shipping of course
Would advise against fitting alloys to a Transit Recovery. They will buckle very easily.
In the link posted above. Alloys for the Transit 350 dual (dual rear wheel) has a load rating of only 936kg
dumper wrote:As I said before losing weight costs money every time I go on a diet my food bill goes up
paul2012 wrote:browuk wrote:Hi all, hope I've chosen the correct place to post this.
Any recommendations on shedding weight from a mk7 crew cab chassis cab 115 or 140ps
I've been thinking of the seats to start with but does anyone know the actual weight of the single and double seat up front as well as the rear bench seat.
Are there alternative seat options that weigh in less? I could remove double seat completely or replace with a single, or if lighter, replace with 2 mondeo or focus seats?
Anything else I could look at to remove or modify that would help save a few kg?
Thanks guys
You'll be adding more weight fitting Mondeo / Focus seats . Transit seats are not that heavy anyway.
Using a Crew cab chassis, the chassis itself has to be extended in 2 places - Section added between cab & rear wheels. Then another section added after rear wheels.
That alone will add to overall weight. Even though bed is made from aluminium, itself will weigh a couple of hundred kg. Last bed I built weighed in at 197kg.
I still have a 8'x4' sheet of aluminium checker plate left over & that one sheet weigh 28kg
Crew cab chassis are not idea for conversion to recovery.
dumper wrote:On the seating front you could go for the light weight rally competition seats for rallying the seats have a time limit on them so have to be changed not sure how long but there must be some about cheap as the only use for them after is road use
