Mk 7 still not starting
Postby oldwoodcutter » Sat Dec 09, 2017 4:39 pm
My mk 7 tipper is 61 plate 115 . Had problems in cold weather it fires up ok, but at very low revs then after few seconds shuts itself off. Starts ok again but still same low revs and ecu shuts off just after engine rattles and smokes.
In November the fault memory was checked, no faults stored, pump and injector relearn and recheck, fault still present after a frosty morning .
So prv replaced, and pressure reg valve, with new filter. Pump and injectors relearned after the new valves fitted.
Still same again, starts ok but low (800/850) revs, a rattle and a clatter then a shut off.
Wait few minutes try again and 2nd or 3rd time it will keep rumming, but never at fast idle, and off we go.
When warm runs perfectly, only 47k genuine miles.
Any words of help gratefully accepted, thankyou.
oldwoodcutter
Re: Mk 7 still not starting
Postby ned » Sat Dec 09, 2017 4:42 pm
Oil pump maybe? Check etis to see if your van was needing the oil pump recall. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby oldwoodcutter » Sat Dec 09, 2017 6:31 pm
Thanks Ned, just checked and no outstanding oil pump recall.
I am wondering oil too, as only happens in cold temperatures, but I change oil and filter every 5k with ford oil and filter.
Previously thought tensioner but Fords tell me tensioner issues were way before mk 7s.
I always drive it very carefully, and do correct starting and stopping procedure.
oldwoodcutter
Postby v8dave » Sat Dec 09, 2017 8:55 pm
Does the throttle work when it first starts ?
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby oldwoodcutter » Sat Dec 09, 2017 11:18 pm
Ah now that’s something else, while it’s just started up,in low revs mode, if I just touch the throttle slightly to bring it up to where it should be on fast idle, it stops itself immediately. It doesn’t like me doing that at all.
oldwoodcutter
Postby karl » Sat Dec 09, 2017 11:58 pm
v8dave wrote:Does the throttle work when it first starts ?
isn't the first turn of the key governed by the ecu on these more fuel , on the euro 5 the fuel system is primed by the tank pump to the lift pump, then the high pressure pump then takes over :wink:
can you post your reg :D so we can check if its euro 4/5
karl
Tranny Lover!!!
Postby mjsroofing » Sun Dec 10, 2017 10:31 am
Heater plugs.
www.mjsroofing.co.uk
2009 2.2 tdci 115ps just over 51k and sweet as a nut ( so far )
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby v8dave » Sun Dec 10, 2017 10:51 am
They can all do odd things when started :!:
When I had a poorly non-start battery it would sometimes run slowly and not respond to throttle for a few seconds before the revs recovered and it behaved.
Does the rev counter stay at zero when it runs slow :?:
v8dave
Postby oldwoodcutter » Sun Dec 10, 2017 12:04 pm
HJ61 OYU. No when it runs slow rev counter shows 800 to 850. Throttle pedal at first is unresponsive to pressure. Thankyou.
oldwoodcutter
Postby ake » Sun Dec 10, 2017 7:23 pm
What oil is in it, and when was it last changed?
Thick old or wrong oil will cause starting issues like this
Postby ned » Sun Dec 10, 2017 7:33 pm
ake wrote:What oil is in it, and when was it last changed?
The op said he does it every 5k with ford oil n filters :wink: N
ned
Postby oldwoodcutter » Sun Dec 10, 2017 8:59 pm
Yes Ake it’s the proper ford oil bought from ford dealer, changed in August . I garage it overnight too to try to keep it frost free. I’ve had this truck for 4 years and every winter I have this blinking same problem, shutting itself off in cold weather startup, and barely ticking over until the motor gets a little bit of heat in it.
oldwoodcutter
Postby knobby1 » Mon Dec 11, 2017 1:32 am
oldwoodcutter wrote:Yes Ake it’s the proper ford oil bought from ford dealer, changed in August .
It might be proper Ford oil but what grade..?? Should be 5w30. The PCM needs to see normal idle rpms for a few seconds before it will activate the alternator and throttle pedal, if the rpm doesn't come up within several seconds, the PCM will shut it down. When cold and if the oil is a bit thick/viscous...she may struggle...mine did this until I put the right grade of oil in it. I un-knowingly, (coz I was a numpty :oops: ) put 20w50 oil in mine, would fire up easily, run for a few seconds, then shut down....had me befuddled until a nice chap on here told be aboot the thick oil issue.
Not totally sure, but I think the latest PCM update helps with this too.
Postby oldwoodcutter » Mon Dec 11, 2017 7:10 pm
The local Ford dealer stores told me ford formula f synthetic 5w 30 . They could have advised me wrong and this maybe totally unsuitable, if it is then they will have a lot to answer for.
What grade should it be please. Thanks.
oldwoodcutter
Postby oldwoodcutter » Mon Dec 11, 2017 7:41 pm
Oh sorry, thanks Mr Knobrot, so it is the correct grade then.
This is a bit of a puzzler, something’s obviously going on, it really does struggle to tick over in these first stages, sometimes stopping and immediately starting itself again, before dying again. Sounds terrible.
oldwoodcutter
