oldwoodcutter wrote:Oh sorry, thanks Mr Knobrot, so it is the correct grade then.
This is a bit of a puzzler, something’s obviously going on, it really does struggle to tick over in these first stages, sometimes stopping and immediately starting itself again, before dying again. Sounds terrible.
OK....if your oil is 5w30, it's the right stuff....
Also, have you had the batteries properly load tested..??....a poorly front battery will cause all sorts of gremlins.
Do you know what code reader your garage used..?? Some of them have trouble with pending or historic codes.
