In need of advice!
In need of advice!
Postby jazzthedog » Sun Dec 10, 2017 7:33 pm
Hello all,
A little over a year ago I brought a 59reg Transit 85 T260M for £4500. Since then I have spent a little under £6000 on the engine.
Looking at other threads the problem seems to be a common one, when starting the engine after it has been sat for a while clouds of white smoke (which according to the garage mechanic smells of diesel) come out of the exhaust. Only thing is I seem to have had the work done to sort this problem out. Below is a list of what I have had done, all at the same garage -
Full service - 07/16
Turbocharger replaced - 12/16
Two new injectors and injector seals and rocker cover gasket replaced - 02/17
Engine flush and oil replaced with 5w30 fully synthetic low saps oil - 03/17
Full service, four new glow plugs, head out and replaced gasket and timing chain - 09/17
New battery and water pump replaced, two new injectors - returned to garage following week as problem unresolved, two new injectors replaced under warranty - 11/17
The garage are now saying they don’t know what the problem is despite the fact it is still happening and seems to be getting worse, more smoke is now being produced and it doesn’t need to be sat for very long before it happens. The van appears to me to drive very well once going. Any and all ideas welcome!
Any clue as to the problem? Should I carry on spending money on it? Is it worth it or should I cut my losses? What will happen if I just carry on driving it? Have I been taken for a ride by the garage?
Many thanks
Dan
jazzthedog
Re: In need of advice!
Postby the_big_fact_hunt » Sun Dec 10, 2017 9:06 pm
have they just randomly replaced parts or have they read the codes properly?
Solve the World food problem.......... Feed the homeless to the hungry
2012 115T350
the_big_fact_hunt
Postby dodgy01 » Sun Dec 10, 2017 9:11 pm
with out wanting to sound rude the first thing you need is to find a better garage
it sounds like they really don't know transits
dodgy01
Postby ned » Sun Dec 10, 2017 9:21 pm
Yes codes read is a must, and it sounds like the garage haven't got a clue, white smoke is usually unburnt fuel, have the garage done a pump and pilot learn, pcm update, checked scv & prv. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby jazzthedog » Sun Dec 10, 2017 9:35 pm
If I’m honest, and at the risk of sounding naive and pretty stupid I don’t know. Kind of wish I asked for advice much sooner!
I know they did hook it up to a computer to get the injector readings but apart from that I’m clueless!
I’m based near Guildford in Surrey if anyone knows of somewhere reliable to get it looked at?
As you can probably tell engines aren’t really something I know too much about.
jazzthedog
Postby Altransit » Mon Dec 11, 2017 1:29 am
Guildford isn't a million miles from Vantuner in Ruislip, West London.
:idea: I would get in contact and see if he can help .....................(MartynX on here)
memberlist.php?mode=viewprofile&u=3419
http://fordtransit.org/ad/redirect/29/
Postby jazzthedog » Mon Dec 11, 2017 8:34 pm
Ok, thanks very much, I will try to call them over the weekend and see what they say
Really appreciate it
jazzthedog
Postby Altransit » Mon Dec 11, 2017 9:11 pm
jazzthedog wrote: I will try to call them over the weekend and see what they say
He's a one man band, not a large company, best to keep your call to office hours, and not on a Sunday :wink:
Postby jazzthedog » Wed Dec 13, 2017 8:15 am
Ok cool, thanks very much, will do
jazzthedog
Postby jazzthedog » Sat Dec 16, 2017 1:07 pm
Hello again, I managed to get a friend to hook the van up to the snap on computer and turns out the injectors weren’t coded, he did this and a couple of other bits and this morning there was only a bit of smoke when I revved the engine! Fingers crossed it’s hopefully sorted! Just wanted to say thanks for the help, have a good Christmas and new year everyone
jazzthedog
Postby richgold » Sat Dec 16, 2017 1:47 pm
jazzthedog wrote:Hello all, A little over a year ago I brought a 59reg Transit 85 T260M for £4500. Since then I have spent a little under £6000 on the engine.
+1 for finding another garage. Thats the first thing you should no.
I had a similar thing a few years ago where I poured money in and nothing came out the other end. After about 6 weeks of messing around I took it back from the garage and to the main dealers and it was fixed within 6 hours.
If they havent fixed it for that amount of cash I'd be looking to get some kind of recompense from them.
Vauxhall Nova GTE 1300 1988 in Royal Blue - My garage ornament.
Volkswagen Crafter 136 LWB 2016 back in white and staying that way! SOLD!!!
Transit 115 Jumbo 2010 - SOLD!
Audi TT 225 Roadster - SOLD!
Mercedes Sprinter 311 LWB 2004 - SOLD!
richgold
cron
