2.4 Mk7 Rwd Gearbox Crunch into 2nd
Postby MercVanMan » Tue Dec 12, 2017 12:16 pm
Ever since I purchased this '07 its had a crunch going into second if rushed, checked the cables but it made no improvement. Its getting worse & annoying now , makes me looking like a learner grinding gears all too often now.
Time to open it up and replace second gear and its syncro.
I have another spare box with a damaged case & would be nice to make a good one from the 2.
Through in a new set of bearing and fresh fluid and in theory all should be good!
Does anyone have any manuals or usefull links or recommendations ??
07 Transit 330S 140ps Rwd
MercVanMan
Re: 2.4 Mk7 Rwd Gearbox Crunch into 2nd
Postby knobby1 » Tue Dec 12, 2017 7:38 pm
If you're running a 140 as per your signature...you'll have the Getrag MT82 6 speed....you'll need some special tooling and pullers to get the gearbox apart and back together properly. It also weighs ~51kg so you may need a bit of help to get it out and back in again.
I'm not saying it can't be done at home, but could be rather difficult if you don't have the required gear to do it.
There's some info in here, you'll need to search through it a bit though..!
http://workshop-manuals.com/ford/transi ... is_manual/
