Cant unlock Doors
Re: Cant unlock Doors
Postby dodgy01 » Wed Dec 13, 2017 7:18 pm
the loom breaking won't dead lock the van and of the side door contacts are not making the door will auto open and unlock the van as it can't read a closed door
if the key ./ lock is dead then it will beed replacing anyway
so a 10mm drill but and drill the centre lock tumblers out then with a small screw driver you can get the sliders to drop out of the tumbler
once you have done this bet a big flat screwdriver and unlock the door
dodgy01
Postby koikichi09 » Wed Dec 13, 2017 10:08 pm
yes I will have get a new lock ,did try what you suggested dodgy ,guess where my drills are , I didn't go in the back as it was a damp meter that stay in the front with all my small testers, I thought I would b able to trigger the c/l if I livened the loom in the door as theres a plug just not sure which one to prod im not saying where it is as not to give too much away
koikichi09
Postby koikichi09 » Wed Dec 13, 2017 10:19 pm
even tried an auto electrician today ,they've moved :shock:
koikichi09
Postby koikichi09 » Thu Dec 14, 2017 1:35 pm
I'm back on the road again :D will post my trials and tribulations later thank you all for the input
koikichi09
Postby richgold » Thu Dec 14, 2017 11:22 pm
dodgy01 wrote:the loom breaking won't dead lock the van
Not in and of itself it cant, but if like me you found your loom had gone when you deadlocked the van and It shorted half way through the dealock cycle leaving all the doors deadlocked except the back door, then yes, it can.
Vauxhall Nova GTE 1300 1988 in Royal Blue - My garage ornament.
Volkswagen Crafter 136 LWB 2016 back in white and staying that way! SOLD!!!
Transit 115 Jumbo 2010 - SOLD!
Audi TT 225 Roadster - SOLD!
Mercedes Sprinter 311 LWB 2004 - SOLD!
richgold
Postby dodgy01 » Fri Dec 15, 2017 11:15 am
glad you sorted
dodgy01
