Van cutting out irregular and diplaying -----
Re: Van cutting out irregular and diplaying -----
Postby Leetgriffiths » Tue Feb 20, 2018 11:18 am
Yea as long as I don't push it over 1500 revs it hasn't caused it to happen fingers crossed. will just take a bit longer to get there :lol: :lol:
Transit MK7
LTG Joinery and Building
http://www.LTG-JB.co.uk
Leetgriffiths
Postby loot » Tue Feb 20, 2018 11:19 am
:lol:
Ids map here
loot
Postby loot » Mon Mar 05, 2018 6:03 pm
Hopefully we can add closure to this thread.
I got the van back and I started again, checked codes (had a flat battery at some point so stored some codes for that.)
So I checked for pcm update, available so installed that.
Checked injector correction factors, number 1 was just lines so I removed the air box and got number 1 and compared the others to what was stored, all good, imputted and programmed them.
Checked throttle pedal, good, checked turbo (minor tests as waste gate turbo fitted) good.
Fuel pump learn.
Injector pilot learn.
All good.
I taped the injector connectors secure for good measure.
Then noticed the pcm loom had been stretched and was rubbing or catching on the sharp edge of the slam panel.
I ran the engine and when I touched the loom it would cut out, tried a few times and the same, so I taped it all up secure and ran the engine for 15 odd mins on tickover but initially I revved it quite hard to see if it would cut out, it didn't and was very smooth for the entire time we were talking.
The engine was initially hunting and I suspect that because if the shorting of the pcm loom it was learning some bad habits.
Anyway initial reports are that it seems right.
The loom was under the washer bottle and the pcm has been removed so either a front end damage previously or something else.
Fingers crossed it was that anyway.
:D
Ids map here
loot
Postby Mad Husky » Mon Mar 05, 2018 6:29 pm
Ahh another owner in Wrexham.
Mad Husky
Postby Leetgriffiths » Wed Mar 07, 2018 9:10 am
I was gonna leave it to Saturday before posting to give it a good week of driving before I got excited lol as have previously thought it was fixed to find out it wasn't :lol: :lol:
I have driven it hard over the past few days and i think I can say loot has found the problem. It's so nice to not have to plan my routes beforehand in case it has a fit :D
Thanks a lot mate for taking the time to check it over. Also your computer was right my windscreen washers seemed to have packed in on the way to meet you. I assumed it was just frozen with the snow but now gonna find the fuse and check it weekend. Again thanks a lot mate
Transit MK7
Leetgriffiths
Postby loot » Wed Mar 07, 2018 10:11 am
That's great, glad to have been able to sort it out :-)
Ids map here
loot
Postby Leetgriffiths » Wed Mar 07, 2018 1:22 pm
Don't suppose you know the fuse number for washer motor do you :lol:
Transit MK7
Leetgriffiths
Postby loot » Wed Mar 07, 2018 2:14 pm
Would it be arrogant if I said I knew everything? Mwahaha ok I don't :oops:
There's no fuse showing for the washer pump it goes directly to the bcm and is bidirectional.
You need to remove the black plastic cover in the passenger front arch to reveal the water bottle, the pump is right there, unplug the connector and check it for corrosion, then meter the connector and earth chassis with ignition on and you should see 12v permanent. Ground is active with the horn button pressed so you might need an assistant. With horn pressed you should see 12v over both pins at the connector but not with no horn pressed.
The wire is known to chafe along that area so you might need to trace it back.
Ids map here
loot
Postby Leetgriffiths » Sun Mar 25, 2018 9:56 pm
Just a little update I found a fuse board behind the one in the dash and it had a fuse blown that works the washer switch works a treat now
Transit MK7
Leetgriffiths
Postby loot » Sun Mar 25, 2018 10:42 pm
8)
Ids map here
loot
