Van cutting out irregular and diplaying -----
Re: Van cutting out irregular and diplaying -----
Postby loot » Sat Feb 03, 2018 11:34 am
Cool :-)
The radio is can bus too i think so even interrupting it could (in theory) cause the issue.
Pioneering diagnostics here going on :P
You'd think bjt would be all over this.
Ps. When did it last blip?
Ids map here
loot
Postby Stumped » Sun Feb 04, 2018 1:13 am
Top run of posts this is people.
Lee I have the same problem with the 'miles to empty' readout flashing back to four dashes. At the same time as the readout flashing the van starts to violently shake like its about to stall, It does this a few times and then does stall.
Then I switch the van back on and its ok for a little bit and then does it again.
Did you lads get to the bottom of the flashing miles to empty readout?
'07 Transit MK7 2.4 RWD PS100 (especially sh*t edition)
Stumped
Postby Leetgriffiths » Sun Feb 04, 2018 9:43 am
So i had to use the van yesterday for a job. After 15 miles it happened again but it drove home as long as I kept the revs at 1500 and after 10 mins of driving it stoped and started driving fine again. Is this limp mode that is happening? Even though there is no lights on the dash?
Transit MK7
LTG Joinery and Building
http://www.LTG-JB.co.uk
Leetgriffiths
Postby loot » Sun Feb 04, 2018 3:33 pm
There's so many things it can be that we just have to disprove what it isn't so going round with a multimeter, also disconnect the radio, maybe the speedo. I would like to swap over the speedo to disprove that. Swap relays around in the engine and glove fuseboxes, just swap the same ones which most are, this will hopefully achieve nothing but if something else goes mad then you know it's the relay.
Ids map here
loot
Postby Leetgriffiths » Sun Feb 04, 2018 3:51 pm
Yea I have tryed to view as much wires as possible today to check for any worn but can't see any. I have also replaced every small fuse in the van thought it was worth a shot for about 16quid.
also while doing all this I unplugged the radio and now don't have the code :lol:
Transit MK7
Leetgriffiths
Postby loot » Sun Feb 04, 2018 6:17 pm
Isn't it written anywhere?
Ids map here
loot
Postby knobby1 » Sun Feb 04, 2018 10:54 pm
loot wrote:Isn't it written anywhere?
Yeah it is...in the radio memory :roll:
Postby loot » Mon Feb 05, 2018 2:32 pm
I've got a spare stereo
Ids map here
loot
Postby Leetgriffiths » Mon Feb 05, 2018 6:25 pm
Is there any code generators for this radio?
Transit MK7
Leetgriffiths
Postby loot » Mon Feb 05, 2018 6:32 pm
No, you can get codes off eBay or the internet for a few pounds.
Used to be able to get them off here but that's a dead subject :-(
Ids map here
loot
Postby andz327 » Tue Feb 06, 2018 1:12 am
YouTube it for codeImage
andz327
Postby Leetgriffiths » Tue Feb 06, 2018 8:30 pm
Don't suppose you know how many relays the van has do you? Thinking of replacing then just to eliminate them seeing as they are all 10 years old?
Transit MK7
Leetgriffiths
Postby loot » Tue Feb 06, 2018 10:23 pm
There quite a few but you'll be looking at the breakers because Ford will want ridiculous money for them.
I think if you can see them in a newer vehicle at the breakers you'll hourly get them fairly cheap.
Ids map here
loot
Postby bambi mk 1 » Tue Feb 06, 2018 11:49 pm
Check the nuts on the fuses under the seat are tight and the contacts are clean especially the one with the big blue and red wire :wink:
bambi mk 1
Postby Leetgriffiths » Wed Feb 07, 2018 7:23 pm
Just checked they were all pretty tight tightened them maybe 2mm. But they do wiggle the part it screws into has a bit of movement in them all is this normal :lol:
Transit MK7
Leetgriffiths
