jumbo 57 wrote:That would certainly be cheaper than a fuel pump Ned.
jumbo 57 wrote:I'd be checking the egr and associated parts. Could be stuck open. It's only supposed to open when on duty cycle, ie, whilst driving and within a certain rev range, not at dle, and not at WOT. (I believe)
https://www.obd-codes.com/p0409
ned wrote:Yes, to plank the egr get the blanking plate with the cut outs for the bolts instead of the one with just the holes, locate the egr (not sure where it is on 2.4) undo 2 x 8mm bolts (don't remove them) slip the blanking plate in and tighten the bolts, job done. N
james66 wrote:So checked
egr valve is closed but I blanked off the valve anyway, still no joy at all
Headache
