ABS & Traction light
Postby brankster » Wed Dec 13, 2017 4:38 pm
I had these lights on a few weeks ago right after I put the wrong bulb in or my brakes. I put the right bulb in and lights went out and were all good for about a week when the lights came back on. The lights seem to come on every other day and if i stop the van and restart it they go away for a day or two. Is there something I should check? Has anyone had this issue? Van still drives totally fine when lights are on.
2013 2.2 125psi Euro5
brankster
Re: ABS & Traction light
Postby dodgy01 » Wed Dec 13, 2017 7:29 pm
im pretty sure the bulb is just a coincidence
have you had any fault codes read ?
dodgy01
Postby brankster » Wed Dec 13, 2017 8:13 pm
Not had anything done. I have read on this site that if you put a single element bulb in that it can cause warning lights. It went on right after I put the bulb in and off right after I put the correct bulb in. So seemed obvious to me that this caused it. If there was a problem would the lights not just stay on all the time?
brankster
Postby knobby1 » Wed Dec 13, 2017 9:05 pm
brankster wrote:Not had anything done. I have read on this site that if you put a single element bulb in that it can cause warning lights. It went on right after I put the bulb in and off right after I put the correct bulb in. So seemed obvious to me that this caused it. If there was a problem would the lights not just stay on all the time?
Have you recently had any tyres changed, brakes looked at etc...
Postby brankster » Wed Dec 13, 2017 11:55 pm
Nothing recently. Hd a service and brakes done in June. Nothing else since.
brankster
Postby knobby1 » Thu Dec 14, 2017 12:19 am
brankster wrote:Nothing recently. Hd a service and brakes done in June. Nothing else since.
You could possibly have a poorly ABS/TC loom, intermittent connection maybe..? Might pay to check all the ABS sensor looms on each wheel.
Postby brankster » Wed Jan 31, 2018 9:57 pm
dodgy01 wrote:im pretty sure the bulb is just a coincidence
Just an update as the lights on the dash only came on when I put my lights on. I put a new bulb holder in and that seems to have fixed it. Just thought I would update as I read that someone else had the same problem.
brankster
Postby bambi mk 1 » Wed Jan 31, 2018 10:04 pm
Came across that a few times :wink: What year is your van 12 or 13 :?:
bambi mk 1
Postby brankster » Wed Jan 31, 2018 10:09 pm
13
brankster
Postby bambi mk 1 » Wed Jan 31, 2018 10:11 pm
brankster wrote:13
Should have read your signature :roll: :lol: I have found this only on euro 5's :wink:
bambi mk 1
