bambi mk 1 wrote:Don't attempt to start it till you check the frost plugs under the rocker cover,they can get caught in the cams and you don't want that and all that goes with it
Yh I’ve drained sump mostly water came out first then oil I’ve taken the oil cooler and filter off and split them oil was coming out where the water pipes go on but I kept filling it with water and no water seams to be coming out the other end so I’m going to get it tested as for the frost plugs I’m going to check them tomorrow or at weekend but can frost plugs have same effect making the water go into the sump
