dodgy01 wrote:as above the oil cooler is the likely culprit
failing that its not good news
+1bambi mk 1 wrote:Take off the rocker cover and check the frost plugs in between the valves You can reuse them Your oil cooler and any plastic connectors may have bit the dust too
knobby1 wrote:No antifreeze is the give-away......Yeah probably the oil cooler...if she's frozen the hoses, the cooler would also suffer, the ice expands and possibly splits the cooler.
Anti-freeze is your friend in colder climates.
We don't get that problem here in down-under land...will be well over 40C here in south-western Sydney today..
Airthies wrote:It will flow where ever theres space. So it'll come up through the block where the galleries/holes are for oil to drain back to the sump. As you squeeze it's got to go somewhere and up n out is the only place it can go.
I'd get it drained as soon as poss though and worrt about where it's coming from after.
Airthies wrote:Then ONLY once its fixed!
Once running I'd do a couple of quick oil changes to make sure any crud from the rusty coolant system water has been flushed out.
Oil and filters are cheap compared to a farqued engine!
Burtie1 wrote:Yh I took hoses off last night to drain water out and bottom hose on radiator after most of the water came out I noticed that oil was coming out aswell so going drop the oil out the sump now and I’ve not tried to start it yet
Users browsing this forum: Altransit
