the dutch guy wrote:Punto443 wrote:I’ve been running not matching batteries of differing age for over 4 years, dragging high amps out them with inverters etc and had heehaw bother at all
But then? What do I know?
I just cut wood
dont confuse luck with knowledge.
dodgy01 wrote:ive been a mechanic for a fair while and now re trained as a electrician
please explain why batteries should be replaced as a matched pair
even fords dont replace them both at the same time if only 1 is at fault
dodgy01 wrote:i understand if you have 2 knackered ones and you only replace 1 of them
bigjohnthomas wrote:MK7 user wrote:the dutch guy wrote:Mixing old and new is a great way to kill new batteries.
+1.
Buying 2 new batteries when 1 is still good is a great way to waste money
please point out my comment were i talk about matched pairs.dodgy01 wrote:ive been a mechanic for a fair while and now re trained as a electrician
a 12v SLA battery has 6 cells. and yes, just like lithium they need to be balanced to prevent overcharging.bigjohnthomas wrote:I would think its like a pack of lipo batteries where you balance charge them
Or the weak cell gets fried and the good cell gets undercharged
But its not as if 2x 12volt batteries have 12 individual cells or enithink init
that a battery is capable of starting the van does not mean it is still "good". you need to look at the resting voltage. if a worn battery has a float voltage of 12.2 for example (~25% capacity remaining) and you put a fresh battery with a float voltage of 12.7v next to it the good one will constantly discharge into the worn battery charging it but it does not hold the charge so it only heats up draining the new battery. this happens every time you turn off the van. this will almost fully cycle the new battery every day wich will kill it real fast. you can see this when you measure the current flow with a camp meter between the batteries when the engine is off.dodgy01 wrote:i understand if you have 2 knackered ones and you only replace 1 of them , but if you only have 1 failed battery why on earth would you replace both
charging the batteries is not the issue here. the problems start when you turn off the engine.dodgy01 wrote:also when they are being charged the main relay is energised so basically the batteries are wired in parallel so the alternator can't tell if there is 1 or 21 batteries
that depends on your setup. plenty of people just do a double starter setup.dodgy01 wrote:the relay separates the batteries once the engine is not running , so what your saying about 1 battery draining the other battery is not even possible
the dutch guy wrote:that depends on your setup. plenty of people just do a double starter setup.dodgy01 wrote:the relay separates the batteries once the engine is not running , so what your saying about 1 battery draining the other battery is not even possible
ps: nowere in my post i am trying to insult you.
apologies for misreading your post.dodgy01 wrote:it was aimed at mk7 mate , not you
