Yea +1 ^^^^bambi mk 1 wrote:I presume you changed the fuel filter,did you use a Ford one
Mcallanm17 wrote:Now that I am looking at Siemens injectors I think that’s what I have will double check tomrrow,
I marked them all and all went in the same holes. Ok a will try and get the new one coded and hopefully that solves it
And to be perfectly honest I haven’t changed the fuel filter yet
Airthies wrote:Is it Denso or Siemens injectors it's got?
Punto443 wrote:Could this be a dpf issue, over fueling when trying to regen?
Forget about coding them in thenMcallanm17 wrote:Airthies wrote:Is it Denso or Siemens injectors it's got?
Cheacked this morning and they are Siemens injectors
