HELP!! what is up with my van !!
Postby stiggy17 » Fri Dec 15, 2017 1:27 pm
Im fed up of this van now !! haha
its a ford transit toureno mini bus 04 plate
2.0 L
its had new pump, injectors, vac pump had allsorts done to it and it still wont f***ing run !
it runs fine for a few miles then it will start to lose power and misfire at around 3000 revs also kicks loads of smoke out when this starts happening
stiggy17
Re: HELP!! what is up with my van !!
Postby Jim Archer » Fri Dec 15, 2017 4:12 pm
What colour smoke?
Any EML light action when it does it?
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby THE A-TEAM » Fri Dec 15, 2017 8:53 pm
For an engine to run fine then start misfiring and kicking out smoke sounds like a problem with the timing somewhere but for it to run ok at first makes me tend to think that something like a damper or tensioner is worn or maybe sticking hence heavy smoking. Black or white smoke would both indicate timings out, but there's so many factors that can cause all this. Have you tried an OBD plugin check?
THE A-TEAM
Postby jumbo 57 » Sat Dec 16, 2017 12:22 am
Yes, back story please. We loves a back story. :)
jumbo 57
Postby stiggy17 » Sat Dec 16, 2017 1:41 am
kicks black smoke out, not had it on a computer. need to get some one to do that for me
stiggy17
