knobby1 wrote:marc1234567 wrote:the timing chain has broken and the rocker cover has been removed and no cradle damage is observable.
the mechanic is not sure and asked me to ask here.
the camshafts can be turned and the mechanic says that could be a bad or good thing. he is unsure as to whether the valves may be bent or whatever.
is there any way there may be no damage to valves etc.
Strange for the chain to actually break..?? If so it will be as Karl mentioned, it's unlikely to bend valves as they're straight on to the pistons and quite robust.... they usually pull the rocker shaft bolts or break the rocker ladder...or both.
If "both cams" can be turned 360 degrees with cyl #1 at TDC and without turning the crank...there's problems, valves should be touching #1 & #4 pistons.
Many Thanks. the turning of the camshafts was done with no particular attention paid to position of crankshaft. Are there parts of the cycle where it would be ok to have the camshafts 360? should we check with cyl 1 at TDC. i think the mechanic said something similar. what are symptoms of rocker shaft bolt damage?
