jumbo 57 wrote:I can't offer you much help other than I think the job is around 4 - 5 hours, possibly less if you do them day in day out.
marc1234567 wrote:2002 mk6 . 2.4 diesel , mechanic is saying based on the diagnostics probably is slipped timing chain and is saying the job is about 9 hours. Can anyone confirm that is about right for the hours?
Is there anything else it could be? the errors were from memory powertrain control unit , 2 faults , one was fuel injection error and other was an expected engine stop . the crank shaft sensor has been changed. easy start failed to do anything.
jumbo 57 wrote:I was easing him in, yes, no starting on heroin is a trifle worrying.
Is that head off or in situ repair guys
I suspect if valves have clattered then it an OFF.
karl wrote:jumbo 57 wrote:I was easing him in, yes, no starting on heroin is a trifle worrying.
they don't bend valves they just push the cams up resulting in cradle breaking or striping the camsaft follower bolts
but either way depending on the damage it has done to the above it can be repaired in situ but if the cam cradle is broken then its head of and another one
jumbo 57 wrote:karl wrote:jumbo 57 wrote:I was easing him in, yes, no starting on heroin is a trifle worrying.
Nasty, so the follower bolts must be pretty soft, can you helicoil them then
jumbo 57 wrote:So that's the carrier, needs welding by the look of it
It must bolt to the head, it's those threads I'm talking about, did you say the bolt strips or do the threads in head strip out?
marc1234567 wrote:karl wrote:jumbo 57 wrote:I was easing him in, yes, no starting on heroin is a trifle worrying.
So is it the case that generally the head is ok and cam cradle is broken and to be replaced?
marc1234567 wrote:the timing chain has broken and the rocker cover has been removed and no cradle damage is observable.
the mechanic is not sure and asked me to ask here.
the camshafts can be turned and the mechanic says that could be a bad or good thing. he is unsure as to whether the valves may be bent or whatever.
is there any way there may be no damage to valves etc.
