karl wrote:was you connected to the internet when you tried the pcm update
a think you need LOOTS help on this one he is a genius at this stuff
helped me a few times
when i get stuck
Airthies wrote:The first two are posibly the result of a failed PCM update ?
P068a is PCM power relay de-energised too early
P0602 is programing error from what I can see.
P2265 is water in Fuel sensor.
Go into module programming and do restore from backup hopefully it's stored your original upload and you'll get away with downloading that. If not you may have to download the asbuilt file and restore from that then do cal update if rqrd iirc?
paul2012 wrote:P0602 Powertrain Control Module Programming Error
PCM has been corrupted. There's no "restore" option on IDS
gav_herts wrote:paul2012 wrote:P0602 Powertrain Control Module Programming Error
Hi Paul,
Would Airthies suggestion of using an asbuilt file work?
gav_herts wrote:The last PCM update would have been performed by the mechanic, although he never mentioned it failing.
paul2012 wrote:gav_herts wrote:paul2012 wrote:P0602 Powertrain Control Module Programming Error
Hi Paul,
As built file ends with .ab
See example below.
You can trick IDS into thinking PCM is blank. Then reprogram using as build data file or manually entering HEX code.
Although, to do this IDS need to communicate with PCM.
Airthies wrote:gav_herts wrote:The last PCM update would have been performed by the mechanic, although he never mentioned it failing.
I thought you tried an update?
If you did and it failed it could of corrupted the pcm in the process....
Best option I think as paul2012 suggests is to try to use asbuilt file and fool IDS into thinking pcm is new and blank.
What version of IDS are you running? You only need v86.00 or v86.04 for your van.
Users browsing this forum: Loudpipes
