MK6 2.4 TDDI output test / Turbo cartridge
Re: MK6 2.4 TDDI output test / Turbo cartridge
Postby ned » Fri Jan 19, 2018 5:05 pm
Jim Archer wrote:If it's any help, once spooled up i.e. as soon as it started to pull properly, my Mk6 120 would show full boost (1.2Bar) and drop back to ~ 0.6Bar at cruise.
Yours may show a lower figure if a lower PS van, plus I increased mine from 1Bar max. When it split the manifold it would only show just under 1Bar.
Jim
You have to wait for your turbo to spool up :shock: :wink: I don't have that problem :P I see between 10 - 20 psi of boost depending on how I drive. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby wicklabilly » Fri Jan 19, 2018 8:53 pm
tanks fir the replies :D
2002 Yella Transit Crew cab Tipper. T350 120 bhp Fairly clean and literally no chassis rust. 2011 MK7 crew cab Transit tipper. T350 115PS Euro 4
wicklabilly
Postby knobby1 » Fri Jan 19, 2018 9:21 pm
ned wrote:I see between 10 - 20 psi of boost depending on how I drive. N
But your signature say you "drive like a t#@t" :wink: :mrgreen: ..!
Postby ned » Fri Jan 19, 2018 9:25 pm
Ah but you don't have to drive fast to drive like a tw@t :wink: I'm in a van so I'm coming out of this junction whether you like it or not :lol: :lol:
It also says fill with fuel but I don't like doing that, fuel gauge roulette anyone :lol: N
ned
Postby knobby1 » Fri Jan 19, 2018 9:41 pm
ned wrote:Ah but you don't have to drive fast to drive like a tw@t :wink: I'm in a van so I'm coming out of this junction whether you like it or not :lol: :lol:
Filled mine yesterday, put 74L into it...@ $1.25AUD/L...cost me ~$93..! Cheap I guess compared to you poor buggers..!
Postby ned » Fri Jan 19, 2018 9:57 pm
:shock: that is cheap, with the exchange rate that's about 60 sovs bargain, I put 20 sovs in yesterday that's about 16L bloody rip off Britain eh. N
ned
Postby Jim Archer » Fri Jan 19, 2018 10:38 pm
Jim
It was pretty good really, with the EGR blank and a Vantuner map it would give full boost from 1200ish, actually nicer to pootle round town in than the mk7 140 as it was shorter geared. 3000@70 on the motorway got a bit tedious mind, the 140 cracks that in 4th halfway down the sliproad 8) should be entertaining when mapped and 70 limiter removed.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby Airthies » Fri Jan 19, 2018 11:19 pm
ned wrote:
It also says fill with fuel but I don't like doing that, fuel gauge roulette anyone N
Filled mine yesterday, squeezed £90 into it and it's only just dipped under 1/4 tank!
In 1999 I imported my smiley van from NZ back to the UK.
When I filled it up in NZ it used to cost me a 10th of my weekly wage.
Back in the UK I filled up and it cost me a 1/4 of my weekly wage! Don't get me started on insurance!!!!!
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby karl » Sat Jan 20, 2018 12:08 am
Back now, well for a bit anyway.....
insurance do take the piss and its all about your occupation/job
then it either put you in lower or higher risk
am in higher risk for having the job i have :(
its all bollocks
if goes up again this year £400 like it does every year am changing insurer but will other insurance companies give me what my current one does :roll: :roll:
and road tax £235 a year
karl
Tranny Lover!!!
Postby fancourt » Sat Jan 20, 2018 11:35 am
wicklabilly wrote:Thanks for all the help thus far.
I wonder if this cable will fit my Transit?
Thanks, Ken
http://www.ebay.co.uk/itm/ELM327-OBDII- ... 1438.l2649
It looks about right - however I got the one from TunnelRat with a different USB-UART chip (Silicon Labs instead of FTDI) and can confirm it works a charm!
https://tunnelrat-electronics.fwscart.c ... 45457.aspx
PS: To get 500K speeds working, you have to use ELMConfig to set the connection speed in firmware - ForScan can't modify this setting. Once you've used ELMConfig to change the connection speed it will work fine in ForScan at the higher speed (at least the TunnelRat part does).
https://www.youtube.com/watch?v=GEjCd-2QKXo
fancourt
Users browsing this forum: Google [Bot], sfnett
