martynx wrote:as the PCM (not IGN) switches it normally on early 125's.
No problem;)scas wrote:martynx wrote:as the PCM (not IGN) switches it normally on early 125's.
didnt realise that- probably wouldnt work then, thanks
What year & model van is it Scas?misterdog wrote:Are you are changing the filter head because it is letting air in ?
I was going to change mine, but throwing the yellow plastic diagnostic bulb away and sealing the hole with a bolt was a much cheaper way of solving the problem..
martynx wrote:Maybe fit a universal type inline fuel pump or facet type.
Sounds alot more hassles than filling a new filter once a year though before twisting it 40 degrees into place. Replace a fully filled new filter to a warmed engine usually works really well.
