NEW MOT RULES REGARDING DPF, E/C SYSTEMS, ENGINE MIL LIGHT
Postby paul2012 » Fri Jan 12, 2018 7:09 am
NEW MOT RULES AS FROM 20 MAY 2018 EFFECTING DPF, EMISSION CONTROL SYSTEMS, DIESEL EMISSIONS & ENGINE MIL LIGHTS
***NOTE*** This is only a draft released by DVSA & more testable items will be changed/added.
There are changes for head lamps, Fog lights & DRL's. Although I thought it was more important to point out the major rules.
I've already posted up the new diesel emission test, Where vehicles will be test against manufacturers limits on another thread - But are included in a screen shot here :wink:
Defects will be in categories
MINOR - advisories (PASS)
MAJOR - MOT Refusal (FAIL)
DANGEROUS - MOT Refusal (Fail & prohibited to be used on the road)
Diesels
"Diesel particulate filters (DPF) should be checked for evidence that the DPF has been removed or otherwise tampered with. Where a DPF canister has clearly been cut open and re-welded, it should be rejected unless evidence can be provided that the canister was cut open for legitimate reasons, such as filter cleaning."
New rule for emission control systems - DPF, Diesel oxidation cat, SCR cat, SCR valves, EGR valves etc
Emission control equipment fitted by the manufacturer missing, obviously modified or obviously defective - Major defect
Exhaust on a vehicle fitted with a diesel particulate filter emits visible smoke of any colour. - Major Defect
Engine MIL inoperative or indicating a malfunction. - Major defect
Petrol
New rule for emission control systems - Cats, O2 sensors, EGR valves etc
Vehicles first used on or after 1 September 2002 fitted with a different engine must to tested to the requirements relating to the age of the vehicle.
If an engine has been modified in any way, it still has to meet the exhaust emission requirements according to the age of the vehicle.
I apologise if this is in the wrong section.
Really needs to go somewhere where it's most visible due to the practice of DPF/EGR deletes etc. :wink:
I will provide updates as more info is made available 8)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: NEW MOT RULES REGARDING DPF, E/C SYSTEMS, ENGINE MIL LIG
Postby Kenton » Fri Jan 12, 2018 2:37 pm
Mods / management, Any way this could be a sticky for 2018? Very interesting and useful info from Paul regarding new MOT rulings. 8)
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby RECKLESS ROAD » Fri Jan 12, 2018 9:16 pm
good that means all buses will be taken off the roads at last
RECKLESS ROAD
Postby paul2012 » Sat Jan 13, 2018 8:30 pm
RECKLESS ROAD wrote:good that means all buses will be taken off the roads at last
Highly unlikely :lol:
paul2012
Postby ake » Sun Jan 14, 2018 12:48 pm
Kenton wrote:Mods / management, Any way this could be a sticky for 2018? Very interesting and useful info from Paul regarding new MOT rulings. 8)
Aye, ok then
Postby paul2012 » Mon Jan 22, 2018 12:34 am
For members that have fitted HID bulbs to Halogen headlamp units.
HID bulbs fitted to halogen headlamp units are NOT permitted & as of 20th May 2018 will result in MOT refusal :!:
If you want HID, then you should replace Halogen headlamp unit with HID headlamp unit :wink:
paul2012
Postby paul2012 » Mon Jan 22, 2018 11:36 am
DRL's & front fog lights on Vehicles first used on or after 01 March 2018
Reverse lights also added for all vehicles first used on or after 1st September 2009
paul2012
Postby Mike » Mon Jan 22, 2018 1:12 pm
paul2012 wrote:For members that have fitted HID bulbs to Halogen headlamp units.
It says “not permitted to convert”. Define convert. Putting a hid bulb in a headlight is no different to puting a halogen bulb in.
Mike
Wind up merchant!
Postby paul2012 » Mon Jan 22, 2018 6:50 pm
Not are you only fitting a HID bulb but also the ballast & associated wiring for them too. :wink:
It states
"It is not permitted to convert existing halogen headlamp units for use with HID bulbs. If it is clear that such a conversion has been carried out, rather than replacing the entire unit with one designed and approved for use with HID bulbs, the headlamp should be rejected."
It effectively also rules out HID projector kits fitted to halogen headlamp units too.
paul2012
Postby Mike » Mon Jan 22, 2018 7:06 pm
It states
What is being “converted”? The wiring and the ballasts aren’t a “conversion” to the headlamp unit. As I’ve already said, swapping a bulb isn’t “converting”. We all know what they mean, but they’re not saying what they mean, which makes it awkward if someone appeals an mot failure. It needs a case to be taken to court to clarify, but afaik it’s never happened?
Mike
Wind up merchant!
Postby bambi mk 1 » Mon Jan 22, 2018 7:12 pm
I was gonna suggest DBVM but on second thoughts we would be backing a loser .
bambi mk 1
Postby dumper » Mon Jan 22, 2018 7:31 pm
I remember on wheeler dealers Ed fitted a set to something and at the end of the show before vehicle was sold they had to remove them as they were not legal
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby paul2012 » Mon Jan 22, 2018 7:38 pm
Mike wrote:
It states
"conversion" - change, to alter, change form from one to another. - Ie "Replacing an halogen bulb for a High intensity discharge bulb"
Just waiting for BJT to come along & says he use candles :lol:
Yes candles are a "Light source" just as HID / Halogen are. Although a incompatible light source just like HID for halogen headlamp units :wink:
paul2012
Postby bigjohnthomas » Mon Jan 22, 2018 7:55 pm
quite simple if it didn't leave the factory like that its been converted
just call me if there's anything else your having trouble with wink
chow for now
justice bigcock
bigjohnthomas
Postby Mike » Mon Jan 22, 2018 9:09 pm
paul2012 wrote: HID / Halogen are. Although a incompatible light source just like HID for halogen headlamp units :wink:
That’s about the only thing a mot could be refused on. Here, have a :wink: as you like them so much. You remind me of another poster who used them in nearly evey post, you do realise what it means?
Mike
Wind up merchant!
