NSG666 wrote:Hi all
I've got a 2012 Mk7 2.2 125hp Transit with a slight fuel leak. I've managed to find the source of the leak which is from a connection to the high pressure pump but I can't find any info on how to repair it. The connector is on top of the pump and vertical, it looks like it's quick release and has a round black body that's a couple of inches long with a 'dust-cap' on top. A fuel line comes off this at 90 degrees and runs back to or from the fuel filter housing.
Can I get a replacement o-ring or does it need a new pipe and connectors? If so what do I ask for from a Ford parts dept.
Many thanks
Nick
ZAPRINSKI wrote:NSG666 wrote:Hi all
Many thanks
Nick
[img][img][/img][/img]
I got the same problem, You think is ok just change the pipe
I got the same problem, how do you know, pipe is leak or pump.
Many thanks
Nick
Embram wrote:Did you get sorted. I have the same leak. Does it have a O ring or does the pipe need replacing. Thanks
