troytroy3 wrote:thanks for the reply pluged it in today no codes
troytroy3 wrote:Worked fine before I changed bcm to high spec ?.
troytroy3 wrote:it shows up in ids as on ???
Ah he left out telling about the change to test your ESP ma lordknobby1 wrote:troytroy3 wrote:Worked fine before I changed bcm to high spec ?.
Ah...you didn't tell us you changed the BCM....it may need changed in IDS....But I'm not sure if ESP is within BCM or PCM..?? I guess it is since it's not working since you changed it..!
andz327 wrote:Ah he left out telling about the change to test your ESP ma lord
