Engine management light turning on and off
Postby Hedgehog » Sun Jan 14, 2018 2:01 pm
I have a 2008 Duratorq tdci 2.4 100ps high top Transit, which I'm currently driving around Europe. I'm mainly taking the scenic route, but if I take the motorway and drive over 100km/h for a sustained period, the engine management light comes on. If I then drive on minor roads for a day or two, the light turns off again. Any ideas?
I took it to a national chain garage to have the fault codes read - they said their code reader can't read English fault codes...
Cheers
Hedgehog
Re: Engine management light turning on and off
Postby martynx » Fri Jan 19, 2018 3:29 pm
It could be one of many things, only option is plugging in & diagnosing with a compatible tool. You can get a £5 bluetooth dongle online & diag its fault codes yourself quite easily & safely, if you use an Android smartfone that it, if your an Iphone user the dongle may need to be wifi type like "IOBD2"
for egr/dpf deletes, power tuning, updates,cloning,speed limiter removal,cruise control, euro 3/4/5/6 limiters & key's !
martynx
Postby axam102 » Fri Jan 19, 2018 10:28 pm
Cheers
AFAIK ODB2 codes aren't "English" it's an international standard. f*** injector will just come up as injecteur baisée in france,
inyector jodido in spain and gefickt Injektor in germany!
axam102
Postby martynx » Fri Jan 19, 2018 10:44 pm
axam102 wrote:
Cheers
That was just an excuse! They have crap diag kit probably ;)
martynx
Postby axam102 » Sat Jan 20, 2018 12:21 am
martynx wrote:
axam102 wrote:
Cheers
or just being butt holes for the sake of it...
axam102
Postby bambi mk 1 » Sat Jan 20, 2018 10:42 am
martynx wrote:
axam102 wrote:
Cheers
Or they cant read cause they are boozed up on the vino :lol:
bambi mk 1
Postby martynx » Sat Jan 20, 2018 10:43 am
bambi mk 1 wrote:
martynx wrote:
axam102 wrote:[quote="Hedgehog"]
Cheers
Or they cant read cause they are boozed up on the vino [/quote]
Yes probably!
martynx
Users browsing this forum: Google Adsense [Bot], TravelRi
