knobby1 wrote:Burtie1 wrote:Hello bambi mk 1
Here is the story I came out of the house one day and thought I’d start the van up as I hadn’t started it for a couple of weeks but first I checked the oil it looked a bit funny on the dipstick then I noticed the top hose was froze it could be squashed so I undid the top hose and got most of the soft ice out and tipped a touch of warm water in and left it the next day I went out and started to fill the header tank as it was empty I was filling it for ages then noticed water homing through the dipstick tube then upon removing the oil filler cap I noticed it was filling up in there so I immediately let all the water out by removing the hoses it was at that time I came on this forum and asked questions as I never knew there were frost plugs in the top of the head so when I was told this I drained the sump and took of the oil cooler then I took of the rocker cover and saw the frostplug sitting there I’ve since put it back in and tested the oil cooler and put that back on cleaned all hoses and put fresh oil in then come to try start and it just turns a fraction
Geezus...That's a long sentence right there..!
If she won't turn over, (and we'll have to assume the battery and starter are ok).... I'm guessing the water may have gone up past the piston rings and into the cylinders, time to get the injectors out and see for sure.
Yes knobby1 it’s always started up no problem and I’ve had the battery on charge aswell so it looks like injectors out this weekend is it a easy straight forward job to take these out
