jumbo 57 wrote:No Bertie, plugs only cap the coolant galleries so you should be fine on that count.
Always clean the core plug seat and apply the thinnest smear of general gasket sealant on the edge of the new plug, then bash the centre until it just reaches a flat state, not beyond.
You did fit them lip edges facing out I hope.
Burtie1 wrote:jumbo 57 wrote:No Bertie, plugs only cap the coolant galleries so you should be fine on that count.
Yh I’ve already done that but it’s not turning over it just turns about a few mil and like bounces back to same place it’s as though it’s hydrolocked I thought that whilst I was filling the header tank and noticed the water coming up in the rocker cover that some may have gone down an open valve into the pots I forgot to mention that I was filling the water up before I knew there was a frost plug pushed out that’s why the water was filling up in the rocker cover
jumbo 57 wrote:No way for water to enter bores from the top, apart from maybe a fubard egr cooler.
But if you keep poring water into an engine with a blown core plug then it may pass the piston rings from below, but you'd have to put a fair few gallons of water in I'd think.
jumbo 57 wrote:An open valve won't let water into a bore ordinarily, even by doing what you did, but if the egr cooler is bust maybe from freezing or internal perforation then it can get in via a flooded inlet manifold.
I don't know these engines intimately, but that's my guess.
If your lucky, the starter motor might not have enough oomph to bend the rods.
jumbo 57 wrote:Hi Bertie,
The reason that water/coolant cannot get into the bores when a valve is open is this....
The valves run in guides with seals at the top of the stems, under the springs. When a valve is opened by the camshaft lobe only air can get into the bore through the inlets ports via the manifold, and then out via the exhaust ports and exhaust system after the usual compression and ignition takes place.
Water/coolant in an operational engine can only circulate through the waterways cast into the head, these run close to the valve ports but they are isolated from each other by a designed thickness of metal.
I must of misread that you'd been trying to fire it up, if you haven't that's good.
I presume you are feeling resistance turning the crank by hand then, ok, don't force it.
My advice is remove the injectors in the first instance, then suck out any water from each bore.
Replace injectors, turn over by hand and if it rotates freely you can move onto the task of reinstating the the injector pipes and bleeding the fuel, at this point it will be fine to use the starter motor. (remember to put the oil in).
One little concern I have is that other frost plugs may be compromised after the freeze, only you can make that call really.
bambi mk 1 wrote:Take out the injectors and see will it turn.How much water did you put in before you realised the plug had popped The water will run out the breather pipe and down through the turbo into the intercooler ect ect if you fill it for long enough
Burtie1 wrote:Hello bambi mk 1
Here is the story I came out of the house one day and thought I’d start the van up as I hadn’t started it for a couple of weeks but first I checked the oil it looked a bit funny on the dipstick then I noticed the top hose was froze it could be squashed so I undid the top hose and got most of the soft ice out and tipped a touch of warm water in and left it the next day I went out and started to fill the header tank as it was empty I was filling it for ages then noticed water homing through the dipstick tube then upon removing the oil filler cap I noticed it was filling up in there so I immediately let all the water out by removing the hoses it was at that time I came on this forum and asked questions as I never knew there were frost plugs in the top of the head so when I was told this I drained the sump and took of the oil cooler then I took of the rocker cover and saw the frostplug sitting there I’ve since put it back in and tested the oil cooler and put that back on cleaned all hoses and put fresh oil in then come to try start and it just turns a fraction
