ford downunder wrote:Hi mate , the starter problem you have is probably caused by the old flywheel , as the old DMF wears all the little filings end up in your starter motor and that is when all the miss firing starts as you call it , i had the same problem and had to replace my starter , they not a a good design ,but after the new solid flywheel no more probs .hope this is helpfull.
ford downunder wrote:Yeh ok I just assumed it did my bad
bigjohnthomas wrote:They both get power at the same time so how can it engage first ?
Its the same coil that engages the gear that connects the live to the starter brushes
