transit 07plate
transit 07plate
Postby demyster » Thu Jan 18, 2018 8:20 pm
Hi all I have my tranist ..and only latley have a door locking problem heres what happens...
I use my fob to lock as normal everything locks as it should .but then a beep ..so I check all doors are shut as this would mean one is open ..all doors shut and its does it again .beeps and unlocks so at the moment cant lock it
Help pls
Mark
demyster
Re: transit 07plate
Postby knobby1 » Thu Jan 18, 2018 8:57 pm
This just means the BCM, (Body Control Module), "thinks" one of the doors is open...one or more of your locks or the wiring/loom to it may be duff....it's a process of elimination.
Easiest thing to try first is to clean the three SLD contacts at the rear of the door, and make sure they line up etc... they're a common problem.
Even though the doors may be closed, if the lock is faulty or the lock switch/wiring is faulty, she'll not be happy.
Re: transit 07plate
Postby demyster » Thu Jan 18, 2018 10:40 pm
Thank you m8 will try out tom .hopefully no one will realise its open fingers cross.but thanks for the advise ..
demyster
Re: transit 07plate
Postby Punto443 » Thu Jan 18, 2018 10:42 pm
99% if the time it’s the rear door loom broken inside the plastic sleeve.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: transit 07plate
Postby knobby1 » Thu Jan 18, 2018 10:56 pm
Punto443 wrote:99% if the time it’s the rear door loom broken inside the plastic sleeve.
Aye...that too...I keep forgetting aboot them... :oops: :oops:
