v8dave wrote:Giving us a bit more information would be a good starting point.
Is it a mk6 or mk7 ?
What year is it ?
Is it petrol or diesel ?
Does it have one battery or two, yes you said you replaced one but does it have a second beside it.
Is there fuel in it ?
Actor63 wrote:i have a ford transit 2 litre 2002 SWB i have had the injectors recond, new timing chain, some new lifters and a injector pump from Euro because my last pump failed.
thats was 18 months ago and drives extremely well no smoke and went through the mot on Thursday with no problems, on Friday it refused to start and when checked it has come up with the code 1608 nothing else just that code, is it a wiring issue or is the pump knackered again i have driven only 5000 miles since the pump was fitted and it is now just out of warranty.
v8dave wrote:OK, sorry for the crystal ball but not all mk6 or mk7 transits are the same.
The two batteries under the seat might be significant.
When you turn on the ignition do all the dash lights come on briefly?
Does anything funny happen to the lights when you engage the starter motor ?
If the van has bee standing for some time it is possible the fuel has drained back to the tank.
If this happens the computer that runs the engine will not attempt to start the engine until fuel pressure returns.
The check for this is with a diagnostics computer, but a good indicator is to remove the fuel filter and see if it is full of fuel. If it is not then fill it to the brim with fuel and refit. If the filter is more than a year old then fit a new one, again filling it the the brim with fuel first.
v8dave wrote:Thanks for the feedback, too many threads just stop after some advise has been offered and we never know what happened next.
Was if the fuel filter ?
Actor63 wrote:apologies if i have hijacked someone's post only just getting used to posting,
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot]
