Transit 2010 2198cc 85T 280S tapping noise-please advise
Postby Wayne87 » Thu Jan 25, 2018 12:58 pm
Hi Guys,
Bought this off a mate a month ago, constant tapping noise coming from engine, he was told it was the Rocker arm bearing that needed replacing. The faster you go the quieter the tapping, apparently.
Local Mechanic put through mot for me, had to top oil up as was low, approx 2.25L, tapping stopped completely for a few minutes then came back.
Removed rocker arm assembly, no obvious fault found, no damage no wear to arms etc. suspecting Hydraulic lifters, but not 100%
injectors are different indicating that two have been replaced at some stage.
No ther signs, no smoke, drives lovely apart from tapping noise.
Any ideas or help would be greatly appreciated.
Wayne87
Re: Transit 2010 2198cc 85T 280S tapping noise-please advise
Postby Altransit » Thu Jan 25, 2018 7:59 pm
Have you checked that the injector clamps are tight :?:
Postby paul2012 » Thu Jan 25, 2018 8:19 pm
Does you engine sound like this :arrow: https://www.youtube.com/watch?v=ePTvmrRIP40 :?:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Wayne87 » Thu Feb 01, 2018 2:56 pm
Hi Guys,
Apologies for the delay, didn’t realise I had any replies, New guy!!
The injector clamps are tight.
Noise is not like the video, it’s more of a loud tapping noise coming from the top end.
Any other ideas?
Wayne87
Postby knobby1 » Thu Feb 01, 2018 7:07 pm
Wayne87 wrote:Hi Guys,
Any other ideas?
Oh dear...I wonder if she's trying to throw a piston...?? :?
Postby paul2012 » Thu Feb 01, 2018 7:26 pm
Any other ideas?
That's what I'm thinking. :wink:
Engine in that vid, load tapping appeared to be top end & not a bottom end knock.
Unfortunately turned out to be blown/cracked piston in cylinder 4 :(
paul2012
Postby Wayne87 » Thu Feb 15, 2018 9:34 pm
Hey guys,
Right, so you guys are definitely on the right track, noise is coming from cylinder 4, we are suspecting a broken/cracked piston as you say. Is there anyway to confirm this other than stripping engine down?
What cost are we talking to strip down, rebuild piston, reassemble etc?
Would a compression test confirm a cracked piston or is that a waste of time?
Wayne
Wayne87
Postby Madtaff » Fri Feb 16, 2018 1:43 am
paul2012 wrote:Does you engine sound like this :arrow: https://www.youtube.com/watch?v=ePTvmrRIP40 :?:
my mk6 sounds like that and hss no guts in it?
Madtaff
Postby paul2012 » Fri Feb 16, 2018 9:01 pm
Wayne87 wrote:Hey guys,
Wayne
Full engine rebuilds I do myself. Cost for parts on bare engine rebuild is £540
Price includes
Cylinder block rebored to 0.5 oversize
4x Oversize pistons with rings etc.
Full top gasket set
Full bottom gasket set.
Head bolts
Mains STD shells
BE STD shells
Price excludes timing chain kit.
paul2012
