Airthies wrote:It'll only pump when it gets a pulse signal it requires on/off/on/off....... to pump.
What model is it? I'm guessing D2?
You can check resistance of pump coils it should be about 10ohms(+/- 0.5ohms.)
If its still not going send it up I've got diagnostics for them now but I'd go through all other things first.
If it's a D2 it doesn't have a magic eye just a temp sensor.
Have ass look through this site for more info
bigjohnthomas wrote:No magic eye
loot wrote:https://www.butlertechnik.com/downloads/Eberspacher_Airtronic_D2_Technical_Manual.pdf
I'll stay out of it now, 1 question though, how does it get the pulse? Is that from within the eberspacher or from the van? In other words does the van need some sort of configuring? I know there's the fuel fired heater there i think.
Is the pump mounted horizontally or at an angle ( outlet higher than inlet)?mjsroofing wrote:D1lc I'm sure it is,
When it was on the van, I use to hear the pump clicking, I applied power on and off but no noise or pumping.
Unless your multi meter specifically says it's measuring ohms then it's no use using that reading.mjsroofing wrote:Airthies wrote:It'll only pump when it gets a pulse signal it requires on/off/on/off....... to pump.
I used my multi metre on the continuity setting and it read 35.
Airthies wrote:Unless your multi meter specifically says it's measuring ohms then it's no use using that reading.mjsroofing wrote:Airthies wrote:It'll only pump when it gets a pulse signal it requires on/off/on/off....... to pump.
mjsroofing wrote:Unless your multi meter specifically says it's measuring ohms then it's no use using that reading.Airthies wrote:mjsroofing wrote:[quote="Airthies"]It'll only pump when it gets a pulse signal it requires on/off/on/off....... to pump.
Users browsing this forum: Bing [Bot], Google Adsense [Bot]
