Hahaha when was the last time that filter was changedThequeenscheese wrote:New filter on hopefully that seems to have done the trick, oddly I thought the van had a neutral position sensor to limit revs, like my old navara had but now the new filters on she revs through 5000rpm with ease where as before she would act like there was a limiter on when out of gear..
andz327 wrote:Hahaha when was the last time that filter was changedThequeenscheese wrote:New filter on hopefully that seems to have done the trick, oddly I thought the van had a neutral position sensor to limit revs, like my old navara had but now the new filters on she revs through 5000rpm with ease where as before she would act like there was a limiter on when out of gear..
Thequeenscheese wrote:Still pulling a lot of air into the fuel,pipe from the filter to pump is there anywhere common faults on these? It's the ford metal filter not the paper one, garage suggesting filter housing maybe fubar, there's a diesel,leak from the leak back pipe also but I wouldn't have thought that would be it?
Thequeenscheese wrote:Turns out the leak off/back pipe was split ..
