Honda415 wrote:Update on the issue so far had a chance to look at it today and while trying to clean the old oil away to trace the leak i found a split in the pipe that goes from the bottom of the intercooler onto the intake with a plug on the intercooler end. Anyone aware of its technical name or a part number? Is it a ford only part? bearing im mind its the rwd model
bambi mk 1 wrote:Honda415 wrote:Update on the issue so far had a chance to look at it today and while trying to clean the old oil away to trace the leak i found a split in the pipe that goes from the bottom of the intercooler onto the intake with a plug on the intercooler end. Anyone aware of its technical name or a part number? Is it a ford only part? bearing im mind its the rwd model
Its called a boost pipe as somebody mentioned in the third post I used to be only available from Ford and comes with the map sensor and is an expensive bit of pipe
ned wrote:Now which smartarse mentioned that in the 3rd post N
bambi mk 1 wrote: Using my head for thinking and my feet for dancing Al
bambi mk 1 wrote:I think this is the earlier hose than yours and has a bigger internal diameter than yours at the egr end but I have seen where people leave a piece of the old hose on the egr and slide the new hose over it and fit a larger hose clip https://www.ebay.co.uk/itm/FORD-TRANSIT ... SwuLZY0Tov Using my head for thinking and my feet for dancing Al
