Mk6 running/starting issues
Re: Mk6 running/starting issues
Postby Honda415 » Tue Feb 20, 2018 1:17 pm
Just had a thought gents plan on patching broken area with silicone hose. I hope to cut out damaged area from intake and around 90° bend to the straight area. I plan to fit silicone hose. But this will be straight with the relative reducer however will this cause more running issues? As the original pipe is tapered and with the silicone repair there would be more volume?
2006 Mk6 115 T350 Jumbo to be a workhorse once it works then potential motocross van.
Honda415
Postby knobby1 » Wed Feb 21, 2018 10:56 pm
Honda415 wrote:Just had a thought gents plan on patching broken area with silicone hose. I hope to cut out damaged area from intake and around 90° bend to the straight area. I plan to fit silicone hose. But this will be straight with the relative reducer however will this cause more running issues? As the original pipe is tapered and with the silicone repair there would be more volume?
Shouldn't bother it too much...
