Prop bearing
Prop bearing
Postby Honda415 » Sun Feb 04, 2018 1:29 pm
Thought i would start my long list of jobs by doing what i thought was going to be easy!!! Nope been on it all morning! Ive cut the old bearing away completely but i cannot for love nor money get the uj yoke off of the end of the prop so i can slide the new bearing on. I cant get a puller on it because i cant get the uj circlips out. To push on the shaft. I am beating it to death with hammer and chisel and even winding out the yoke bolt against a spacer to liad it up and get it to shift with no luck. Short of buying myself a bottle of gas with a decent blow torch any ideas??
2006 Mk6 115 T350 Jumbo to be a workhorse once it works then potential motocross van.
Honda415
Re: Prop bearing
Postby scas » Sun Feb 04, 2018 3:48 pm
theres a -i think 13mm- bolt in the middle of the propshaft holding the uj on. loosen it about 4 or 5 turns then push/poke the retaining clip out, it looks like the letter u/n. no need to take the bolt out. then hit the uj out remembering to mark it and the prob for balance when youre sticking it back together. a normal 13mm open spanner will loosen the bolt
06 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 90
05 mk6 2.4 di 115
new 06 mk6 2.4 di 115
new 00 mk6 2.4 di 125
can you see a pattern
scas
Re: Prop bearing
Postby Honda415 » Sun Feb 04, 2018 4:38 pm
Its a 17mm on mine its loose and been using it against it the uj itself to try and jack the yoke/flange off but still wont work. Had enough for the day ordered a propane blow torch to see if i can heat it up more than my little hand held canister will. Then more hammering
Honda415
Re: Prop bearing
Postby RustBucket » Sun Feb 04, 2018 5:00 pm
Haha the dreaded prop bearings. I'm not even joking its one of the most piss taking jobs I've ever encountered. I was beating the living death out of it for three days with heat on it. Went through a litre of penetrating fluid from soaking it and going back to it.
Had it held in the vice, blow torch heating it up but trying not to burn out the UJ's. Tonnes of oil. I nearly cried a tear of joy when it cracked the first mm and I knew I was winning.
What a joke! Tackled it one Sunday before work and ended up missing 3 days graft :x
Bigger hammer :wink: Good luck :lol:
Mk7 lwb hitop. 2.4
RustBucket
Re: Prop bearing
Postby jumbo 57 » Sun Feb 04, 2018 11:21 pm
Did mine recently, an absolute c*nt of a job, same as you, seized on.
I used my plumbers torch with the regular gas, which is rated at 'pants' for this kind of job, you may wish to try MAP gas, which I believe is much hotter burning.
10 minutes of heating is mind numbing to undertake, but necessary because everything is a cold sink.
It will release eventually, and I too had to hit the beejesus out of the yoke as well as using the bolt as a press.
Wire brush the splines and apply plenty copperslip on it when you refit, and it's important to renew the locking tab washer, I got a kit of 2 new bolts, 2 new horseshoe spacers and 2 new tab washers for £14 on ebay,
Stealer wanted £20 for 1 bolt and 1 washer.
jumbo 57
Re: Prop bearing
Postby Honda415 » Tue Feb 06, 2018 5:19 am
Thanks gents looks like im in for some fun!
Honda415
Re: Prop bearing
Postby Honda415 » Sat Feb 17, 2018 10:16 pm
Well update on the prop bearing ended up taking prop off completely and visiting an old farming friend using the aceteylene and lots of hammering for over an hour to get the flange off! So its all seperated pending re-dressing of flange etc so can be re-assembled and fitted. Thanks for all the advice so far!
Honda415
Re: Prop bearing
Postby ABA » Sun Feb 18, 2018 3:41 pm
if you have to split your prop shaft mark it first on both surfaces where it splits so when you put it back together it goes back exactly as it was or if you put it back together with out marking it you have just unbalanced your prop shaft
ABA
Re: Prop bearing
Postby Honda415 » Mon Feb 19, 2018 11:24 am
Ive marked/scribed everywhere to ensure it goes back the same way it came off.
Honda415
Re: Prop bearing
Postby Honda415 » Mon Feb 26, 2018 5:02 pm
Prop finally rebuilt with plenty of copper slip on the bearing and splined shaft. All together and back on ready for the other to fail! Lol
Honda415
