knobby1 wrote:Sounds like the dreaded duff throttle pedal, but yes, definitely fit a new fuel filter ....and a nice service wouldn't go astray.
Also, you may have grief this year at MOT time, they'll be checking for EGR function and fitment from May 20th....see here:
viewtopic.php?f=5&t=184386
ned wrote:You've never changed the fuel filter I change mine every 5k, if the fuel can't flow the van can't go N
daraioj wrote:I'd personally start with the SCV. It's just a plug and two screws. It doesn't take long at all. Then a pump learn and if the problem was the scv you'll notice the difference straight away.
Then you can test the prv and do the leak off test when you've got more time.
I got my Denso scv from Amazon. I'm in Spain though. If I was in the UK I'd probably go for pfjones.
Antomac wrote:Just check your egr blanking plate first. Plate could be burned through. Might be the duff egr causing the problem.
You'll need to do a pump learn which is basically calibrating the scv and you should reset the counters for the prv. (Number of times it opened and duration if I remember correctly).supadik wrote:daraioj wrote:I'd personally start with the SCV. It's just a plug and two screws. It doesn't take long at all. Then a pump learn and if the problem was the scv you'll notice the difference straight away.
Thanks for the reply. If I do as you say and just start by changing the SCV do I need to do any of the pump reset / pilot learn stuff or just get in and drive? I'll have a look at this pf jones as I've noticed it mentioned a few posts I;ve been reading.
Cheers
Rich
Every 5k.....Ned thats only coz you use chip fat for fuel from yer local chippy withoot filtering the crispy bits ootned wrote:You've never changed the fuel filter I change mine every 5k, if the fuel can't flow the van can't go N
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
