Hi guys .
ive looked at some you tube videos but cant seem to get something for a mk7 front.
parts pics seem to have no wheel studs. i was thinking of just swapping the hub
any advice of places to buy etc most welcome
maccavvy wrote:Hi guys .
maccavvy wrote:ive bought the flange bearing combo... my mates allowing me to use his garage sunday so i should be good . then have a press. are new studs needed ???
i havent ordered them
Studs usually come with the new flange, there is somebody on ebay that sells flange and bearing already pressed onknobby1 wrote:maccavvy wrote:ive bought the flange bearing combo... my mates allowing me to use his garage sunday so i should be good . then have a press. are new studs needed ???
You should be able to use your old studs if they're still in good nick...just whack or press 'em out of the old hub and whack or press 'em into the new one...I bought new ones but I could have used the old ones if required.
Sometimes with you poor buggers in the UK the bearing housing can corrode a bit making it difficult to remove from the knuckle, but a bit of elbow grease, (and BJT's famous #0001 removal tool), should see you sorted.
A bit of copperslip on the bearing housing and the "dummy axle" splines when re-assembling will help keep the corrosion away.
andz327 wrote:Studs usually come with the new flange, there is somebody on ebay that sells flange and bearing already pressed on
That's cause yer fae doon there sirknobby1 wrote:andz327 wrote:Studs usually come with the new flange, there is somebody on ebay that sells flange and bearing already pressed on
I had to buy the studs separately, none of the hubs I had seen on fleabay had them fitted.
maccavvy wrote:as it happens wasn't too bad to change over . did it on my mates 2 post and had access to press too.
also spotted 2 shagged drop links and a worn track rod end. feels like a new van now
