Is there no another wire/plug in that area on the rwd that can get mixed up ??bambi mk 1 wrote:Crank sensor wires trapped between engine and gearbox will show that fault
andz327 wrote:Is there no another wire/plug in that area on the rwd that can get mixed up ??bambi mk 1 wrote:Crank sensor wires trapped between engine and gearbox will show that fault
Yeah that be the oneknobby1 wrote:andz327 wrote:Is there no another wire/plug in that area on the rwd that can get mixed up ??bambi mk 1 wrote:Crank sensor wires trapped between engine and gearbox will show that fault
They don't have a speedo harness, but they do have a reverse light switch harness. Heard of people mixing them up before, I believe the plugs are similar.
Verdict ????george999 wrote:just had the RAC out to have a look and there is no RPM at turnover and the crankshaft sensor is loose, she also seems to be drawing a lot of current as well, so tomm morning she will be recovered to the nearest dealer.Which is adams morey
