Looking to swap the pcm over on my 09 2.4 115, is it possible using forscan? Have searched and only ids is mentioned.
Also, when the new pcm is programmed to the van, can the old pcm be plugged back in and still work?
Reason for this, I have this spare pcm which is remapped but is for the 140 turbo, which I also have. I can't fit the turbo then drive it somewhere to be programmed as it will have no control, and doubt I can take it to get it programmed then drive back with the wrong turbo fitted!
