Starter fault
Starter fault
Postby spg handyman » Wed Feb 14, 2018 5:24 pm
Hi got a anoying problem on my 2011 trend 115bhp mwb
When i turn the key to start position i get click and lights dim and then it turns over quickly and starts.
I have for checked volt drop on earth and live both ok . But i have noticed that the battery voltage drops to 8.4 v which is low . If i connect a boost pack it is still the same .
I have renewed battery, starter and ignition switch .
Any idea's
Thanks in advance
Steve
spg handyman
Re: Starter fault
Postby spg handyman » Thu Feb 15, 2018 4:14 pm
Tried another battery on now getting fault less often and seems ok with boost pack .
What is the correct battery for a 2.2td fwd ? As it appear there doesn't appear to be enough cranking current .
spg handyman
Re: Starter fault
Postby ned » Thu Feb 15, 2018 6:10 pm
Fit the biggest battery you can fit under the seat, Bosch 110 batteries are good, also fit the highest CCA battery you can get, have you only got 1 battery under the seat?. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: Starter fault
Postby spg handyman » Sun Feb 18, 2018 6:51 pm
Only got 1 battery under the seat . Did wonder about putting a second 1 under there in parallel.
The one I've got is a 720 cca but it just the initial hit as the starter engages and then it spins over fast and starts .
Steve
spg handyman
