Grimey Injectors
Grimey Injectors
Postby MJ80 » Thu Feb 15, 2018 10:34 am
Pulled the injectors out this morning to get them cleaned and tested in desperate attempt to get mobile again.
I don’t know if this is normal or if I should get looking at the pump. The ends of the injectors are all black and two of them were quite gritty. I ran the grit over a magnet and it stuck.
One of the injectors was missing the copper seal at the bottom and the shaft looks really worn around that area.
I haven’t had anything magnetic out the fuel filter when it was drained.
Any ideas what it could be?
2003 Mk 6 125 tdci T350 - I have no other choice
MJ80
Users browsing this forum: Google [Bot], knobby1, W3C [Validator]
