Does this steering wheel fit my mk7
Postby Steve192 » Thu Feb 15, 2018 8:39 pm
Hi guys. Can someone tell me if this steering wheel is a direct replacement for my mk7 Transit van 2012.
Steve192
Re: Does this steering wheel fit my mk7
Postby Punto443 » Thu Feb 15, 2018 11:33 pm
It will fit, but the transit airbag won’t.
Also the steering angle sensor will need recalibration.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Steve192 » Sat Feb 17, 2018 11:29 am
I have the air bag that came with the wheel too.
Are all the connectors the same? And earthing points etc?
What do you mean by recalibrate the steering angle sensor? Is this a must before you can drive it?
Thanks for your help
Steve192
Postby blue estate » Sat Feb 17, 2018 11:49 am
Steve192 wrote:I have the air bag that came with the wheel too.
Yes or the ESP/ABS will be out and it will drive funny
72plt MG 5 ev estate Battery car
blue estate
Postby loot » Sat Feb 17, 2018 4:22 pm
Only affects esp really, check if you have esp if not you'll be ok but might need to get it tracked up anyway (might).
Ids map here
loot
Postby Steve192 » Sat Feb 17, 2018 7:03 pm
I do have eps yes.
Is it the manual adjustment method I’ve seen on thread in here? Or is it an ids job?
Steve192
Postby Steve192 » Sat Feb 17, 2018 7:04 pm
Is it only the 4 spoke mk2 focus and 4 spoke c max steering wheels that fit straight on without any faffing about?
Steve192
Postby loot » Sat Feb 17, 2018 7:06 pm
Iirc the holes either side of the centre nut on the transit are on an angle, the others are straight which confuses the steering angle sensor.
It is a simple calibration in ids, don't know if forscan can do it?
Ids map here
loot
Users browsing this forum: Altransit, Google Adsense [Bot], Majestic-12 [Bot]
