Dumped my power steering fluid on the ground. How far should
Postby Digrizrat » Thu Feb 15, 2018 11:17 pm
Suddenly lost power steering, and dumped a lot of fluid on the ground. Multiple liters from the look of it. Luckily I was only turning around in a carpark.
Drove 4km to a friendly place to park for the night, it's a anoying to turn tightly, but driving is suprisingly doable.
Is it safe to drive 230km (145miles) back to my worksite? it's consistently below zero outside here in Sweden so the heated workshop would be a reeeeely nice place to work on the van.
I'm worried about both road safety and causing further damage to the van. Should I disconnect the belt to stop the pump spinning while dry?
2013 mk7 2.2 fwd.
Digrizrat
Re: Dumped my power steering fluid on the ground. How far sh
Postby bigjohnthomas » Thu Feb 15, 2018 11:19 pm
your pump will seize :|
squeek squeeek belt snapped
yes yes disconect pump allgoodperfect
power sterrimgisfor pussies
They call me Mr Bum Drastic
bigjohnthomas
Postby Punto443 » Thu Feb 15, 2018 11:29 pm
But doesn’t it also drive the water pump?
145miles without that Cant be good :?
2018 ???????
my old mk7
my old mk6
my xr3i
2011 qashqai.
Punto443
Postby bigjohnthomas » Thu Feb 15, 2018 11:31 pm
pair of tights should sort that
bigjohnthomas
Postby Digrizrat » Thu Feb 15, 2018 11:41 pm
Punto443 wrote:But doesn’t it also drive the water pump?
Punto, you always ask the big questions. Without my Haynes manual that's back in the workshop, can anyone help us out?
Digrizrat
Postby Punto443 » Thu Feb 15, 2018 11:43 pm
It does, it shares the shaft, wp is behind the ps pump.
What’s damaged, pipe?
2018 ???????
my old mk7
my old mk6
my xr3i
2011 qashqai.
Punto443
Postby Digrizrat » Thu Feb 15, 2018 11:50 pm
Punto443 wrote:It does, it shares the shaft, wp is behind the ps pump.
It's dark and I don't want to crawl in the snow tonight. I'll have a closer look in the morning.
I'm hoping it's just a pipe.
I need the water pump, so the belt stays on I guess.
And there's no way to tell how long the pump would last before it seizes and snaps the belt. Leaving me stranded without a water pump.
This is looking like I shouldn't drive it back to the nice heated workshop....
Digrizrat
Postby Punto443 » Thu Feb 15, 2018 11:53 pm
Probably be a pipe, usually where they run along the chassis leg
2018 ???????
my old mk7
my old mk6
my xr3i
2011 qashqai.
Punto443
Postby Digrizrat » Thu Feb 15, 2018 11:58 pm
Punto443 wrote:Probably be a pipe, usually where they run along the chassis leg
Is it worth buying a set of hoses? They're all the same age after all. Is it just one pump to rack, and one return?
Digrizrat
Postby bigjohnthomas » Fri Feb 16, 2018 12:04 am
my low pressure pipe was leaking last week
fifty bloody four turnips for a new one :x
they are alloy tubes
bigjohnthomas
Postby bigjohnthomas » Fri Feb 16, 2018 12:09 am
2 alloy tubes going to the rack a low pressure and a high one
then some rubbery bits to connect them to the res and pump
this is the second van ive had to replace the low pressure pipe
bloody ford
bigjohnthomas
Postby Punto443 » Fri Feb 16, 2018 7:58 am
My low pressure pipe was also leaking a while back, think it was about £50ish from ford
2018 ???????
my old mk7
my old mk6
my xr3i
2011 qashqai.
Punto443
Postby the dutch guy » Fri Feb 16, 2018 11:30 am
i will give the pump 10km at best with a lot of burning oil before it locks up and takes out the belt wich stops the waterpump and alternator.
fix it on the spot or tow it.
Mk6 SWB TDCI 125
the dutch guy
Postby Digrizrat » Fri Feb 16, 2018 3:45 pm
Had a look, the high pressure hose had popped out of the pump, i think the threads are damaged.
We've sealed it up as best we can for now, and hopefully I can buy a new hose and fitting.Image
Digrizrat
Postby Punto443 » Fri Feb 16, 2018 4:31 pm
The Wee nut is a compression fitting and separate to the pipe.
I just sold a pipe and nut brand new for £40 a couple of weeks back :lol:
2018 ???????
my old mk7
my old mk6
my xr3i
2011 qashqai.
Punto443
Users browsing this forum: Bing [Bot], Rubz
