MK 6 NO POWER FROM BATTERYS AFTER A STARTER MOTOR CHANGE
Postby slowpete » Thu Feb 15, 2018 11:41 pm
Hi folks, I had a fault with my starter motor caused by bad fitting , when I turned the key off the starter carried on running, I fitted a new starter but have no power at all in the bus, if I jump start from under the bonnet all the lights come on and the new starter runs, but after taking the jumper leads off ,still no power from the internal battery's, help please, thanks.
slowpete
Re: MK 6 NO POWER FROM BATTERYS AFTER A STARTER MOTOR CHANGE
Postby Punto443 » Thu Feb 15, 2018 11:46 pm
The battery terminal lead has a built in fusible link, if blown, it’ll need replaced.
Think it’s built into the negative terminal?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Altransit » Fri Feb 16, 2018 1:07 am
Punto443 wrote:The battery terminal lead has a built in fusible link, if blown, it’ll need replaced.
It is part of the negative lead, the one under the drivers seat.
Try attaching a jump lead from the battery negative to a good earth, and see if you get power :idea:
Postby slowpete » Fri Feb 16, 2018 3:58 pm
Thanks guys , put an earth lead to a good earth and all was fine, it must be the inline fuse that needs changing.posting.php?mode=reply&f=5&t=185162#
slowpete
Postby ned » Fri Feb 16, 2018 7:56 pm
Mine doesn't have a fuse on the battery earth :shock: feel left out now. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby ake » Sun Feb 18, 2018 4:44 pm
ned wrote:Mine doesn't have a fuse on the battery earth :shock: feel left out now. N
I Thought that all mk 6 did.
Its a white box bit on the lead
Postby ned » Sun Feb 18, 2018 4:53 pm
I think at some point before my ownership the lead has been changed :wink: N
ned
Postby ake » Sun Feb 18, 2018 5:16 pm
that could explain it!
Postby bambi mk 1 » Sun Feb 18, 2018 5:23 pm
Its ok Ned ,you are earthed to the moon when you have a 666 tdci :lol:
bambi mk 1
